Adjustable endlinks
o0n8
Still have noob questions
74 Schwinn Varsity, 75 Camaro (Project), 04 6 Wagon
so i'm new to all of this and while changing my springs i had to cut off one of the endlink bolts and needed to replace the endlink. I went with the AWR adjustable endlinks cause they were only $5 more. As I said i'm new to tuning so what is the advantage of having these?
no one knows i take it
The AWR is nice because it allows you to adjust according to your ride height/drop. The biggest addition to that whole set-up would the the clunk fix, by AXR. I'm sure you noticed the strange angle the bottom of the end link was in, the Clunk fix re aligns the rear sway bar a bit lower to help those bushings and endlinks out a bit. From what I here they also help stabalize the rear it it more as well. I'll be finding that out this week.
Correct!
they are installed so now i'm just gonna play with them. i set them up to be a little longer than the stock endlink for but it looks like thats really the only way to adjust them is bigger than stock. the way the are made adjustinst will be easy, just need a 9/16 wrench once the wheel is off
Is your Car Lowered? The only reason you need adjustable end links is to compensate and make up for the difference that your car is Lowered. Also if you r Car is lowered why would you make them taller then Stock wouldnt that defeat the Purpose of having them? If anything they should be lowered to compensate for the drop difference
