AC Compressor relay .......where is is located ??
WWNJCX7
Hello All,
My AC stopped working in my 07 CX7 yesterday, after a bit of troubleshooting it appears that the compressor is not engaging which makes me think it could be the relay. Already checked the 2 fuses (visually not with a tester) they looked fine. Now I am thinking it could be the relay for the compressor unit, cannot seem to fine the exact location ?? Does anyone have a link for the wiring diagram that would illustrate the relay location ? Also, recently got the car back from Mazda for a timing chain replaement and I wonder if the tech removed the wire socket for the compressor to get it out of the way, perhaps it came loose but since its mounted on the bottom of the engine I cannot see it from the top side. Does anyone know where the wire feed comes into the compressor unit, does it need to be accessed from the bottom of the car.
Thanks in advance, we are expecting temps near 90 tomorrow here in NJ, and hot for the rest of the week......ugh
please limit the same question to 1 sub-forum as its not needed.
please check your other thread as i replied to you.
