So I had a new set of wheels/tires mounted today and I soon noticed the ABS and TCS lights were on. I've driven about 30 miles now and they're still on. The ABS definitely isn't working, I tested it and left some long darkies (no)
Is this normal after a wheel swap? Is it supposed to go away on its own?
Is there an easy reset like disconnecting the battery or pumping the brake with the key in the ignition?
Or did the folks at the tire place mess up one of the sensors?
I did not install TPMS in the new wheels, so that light is obviously on. Are the systems related? I didn't think they were.
