ABS Light
sean22306
Contributor
2003 Mazdaspeed Protege
My ABS light comes on when the car goes over 100mph. Everything seems to work fine still. Any idea as to why the light would come on?
it could be an electrical thing. sometimes my ebrake and abs light come up even when the ebrake isnt engaged. but then again what do i know hahaha
check your brake fluid?
littlemimus def check yours. my miata's ebrake light comes on when my brake fluid is low. and can go on and off depending how much is in there and how i take a turn
Yea I got the same problem. Both lights are on now. Thinking it's a wheel speed sensor. My fluids are topped. I did my front pads and rotors. Not sure if because the rear are worn they can throw a light.
