?? About clunking sound in the rear?
D_Roc7822
So I noticed this a couple days ago and really didnt think anything of it.. but now its getting kind of annoying and even had someone ask me about it. When I turn fast I hear a clunking sound coming from the back of the car. And also when I go over bumps as well.. I hear a clunk or a jingle sound coming from both the front and the back of the suspension. I have Eibach Sportlines as my suspension and they have been installed for quite a while as it was the first mod I did to my car. Possibility that it could just be a loose bolt? Or something a lot more serious? Or are my shocks blown? Any help would be great.. thanks.
check the sway bar end link connections first... these have been known to come loose. They have a stud which you need to hold in place with an allen wrench while you torque down the nut which I believe is 17mm
well so far everything is tight.. I checked the sway bar link and a couple of the bolts that we took off and all were tight. I didnt take the wheel off or anything so I still have to check the actual shock bolts and a few other things. But everything so far is tight. It just makes to much of a coincendence that both back struts/shocks would go out at the same exact time. The car only has around 13k miles on it.. and like 6-8k with the sportline springs on there. I do like the corners a lil to much so I dont know. If it is the shocks.. then I think Im just gonna save up for the BC Coilovers. The sportlines are lets say less than comfortable for someone who drives 50-70 miles each day of the week.
