RAAZ227 said:
From my "HONDA" experience, you can run the stock ECU 10-12psi no prob. Here is the reason why you can even with a P5! (for those who don't believe me):
-upgrade the injectors
-upgrade the fuel line (steel braided -8 or -10)
-fuel rail a must. Not sure if they are avail. but build one
-a REAL adjustable fuel pressure regulator (SX Engineering)
-inline fuel pump
-MSD Digital DIS ignition system
-MSD Plug Wires
-Cam Gears
With just those mods. I am very sure you can run higher boost on the P5 (above 7psi). This has been PROVEN for a long time. The MSD will handle the ignition systems requirment. You would use the cam gears for the cam timing. With those (2) items you can now pump more fuel into it. Now the fuel can be burned. Yeah, additional injectors would be a good route for added saftey. 10-12 psi isn't that what it is thought to be. Try tuning for 15+ psi. It seems like everyone is making it more complicated than it really is. You don't need to drop $1500+ for a standalone fuel managment system just to run 10psi. I dont care if our cars have "NO TIMING CONTROL" it can be done. Just be safe from the begining. I havn't seen anyone with all these mods just yet.
I am not trying to start a war, just making a true argument!
raz,
please dont take this the wrong way but we are first not dealing with a honda ecu or honda valve and ignition timing.
we have a base engine that was transformed with certain ecu sensors meant to pass emmisions . not for performance.
this is important to remember.
next in order from which you listed them:
1. i agree with the upgrade in injectors
2. my fuel line is stock and is plenty large enough to produce the hp #'s needed with gasoline as my fuel. if your talking alcohol. well......( just kidding) fuel line diameter is ok
3. why?? dont need it leave the stock system alone and build around it.
4. a real adjustable is available thru BEGI and vortech you just need to know how to match them to your application. if you want stock pressures then go to the one you are suggesting.
5. i agree
6. i wont get into it but it DOES NOT WORK WITH THE STOCK ECU.
7. i dont know about msd but upgraded wires are ok for high boost application. the stock arent bad if your not increasing the voltage in the system IMO its a waste of money
8. hard to get. this was earlier in the year so rite now i dont know
but a great idea.
also in regards to your quote that you have not seen any of theses mods on a p5 yet. please dont say things like "10 psi with out timing control is possible".
you really need to remember my top statement. this is not a honda and the proteges use a MAF not MAP so we dont have the luxury of using check valves to fool the computer and think it is under load all the time.
i understand what your saying to a point and you mean well BUT this ecu DOES NOT work with us that easily. we dont have the aftermarket support yet to lower that "1500.00$ " price tag
