Figured this was due for an update
I finally got around to working on the car this week after putting it in storage on November 6th....
Upgrades for this year are some improvements to the exhaust and then JIC coilovers and AWR rear trailing arms and updated sway bar bushings to get rid of some of the clunk hopefully...
I've been fabbing the new exhaust and it is a MONSTER compared to the old... should genuinely yield a rather large leap in performance... I'm using a 3" 90 degree mandrel bend pipe to a 3" flex joint right into my 3" straight through exhaust... the Evo 3 O2 housing I'm using is a massive 2.5" straight through right from the turbine and I'm porting it to about 2.75" to flute nicely into the 3" exhaust and yield a good transition that should yield more power... I can't imagine how much better this should make things!
I'm also in the process of relocating my thermostat (new DP is too big with my turbo location to keep the thermostat where it was) and remote mounting it and putting in a 160 degrees thermostat (versus our stock 190 degree)... Also trying to salvage my AC system if at all possible as the girlfriend has made it rather clear that she won't be riding in the car much if I want to drive around in it without AC for another year... we'll see I guess... If shifting it down and out a little and going to a longer belt doesn't do it for me I'm going to have to pull the system.. which isn't bad from a racing standpoint
I'm also having one of the flanges on my turbo manifold flattened as it was leaking pretty bad this last year... so that will help as well getting that taken care of so I have no exhaust leaks for once...
Lastly, I'm still trying to trace my oil consumption issues... I found oil residue in the intake manifold... and I found oil residue on the intake port of the turbo itself which means that I likely am pulling oil through my air intake which is drawing off the valve cover to ensure that the crankcase stays ventilated... so I found traces of oil in all sorts of places, but none of any quantity... and considering I "lost" about 8-10 quarts of oil in the 6,000 miles I put on last year you would definitely think it would show up definitively... but it hasn't...
My debate now is if I pull the head and check for cylinder wall glazing... it's easy enough to do and I want to re-torque the head studs... but I fear what I might find and what that will cost me in time and money...
My compression numbers were decent.. and leakdown was all under 20% (I didn't measure it accurately enough to tell you exactly what each was.. just did a quick check to make sure everything was under 20% which means the rings and piston crowns are intact even if the seal may not be that great overall)... so that's the word from here!
Hoping to have it on the road by the first week of April... so here's hoping!
