pdhaudio83 said:
well its weird because wires 1 and 3 are on different coil packs, just odd they would both cause a misfire at the same time...
Yeah THAT would be odd.. but one of them going or them both being intermittent would be reasonable...
So anyway.. I'll get to work on my car in a bit over an hour... but here is my "symptoms" list right now..
Idle SOUNDS lumpy, but overall is smooth (as far as the motor itself.. no excessive shaking etc). Exhaust note is very aggressive and separated... like a drum beat... has been likened to an idling Harley... idling at 880 rpm's and 10-14 degrees timing.
Exhaust sounds breath and the car hesitates and stumbles while trying to accelerate or rev until above 2200 rpm's... once above 2200 rpm's feels pretty smooth but will occasionally misfire.
At approximately 3,000 rpm's complete ignition breakup occurs with constant misfire's and gasoline vapor lighting at the tailpipe (backfire).
Can not accelerate through the breakup... AFR's remain reasonable constant but will show lean dips following misfires etc.
JandS does NOT see detonation but will show occasional noise.
On deceleration, no misfire or roughness at all and good clean exhaust note all the way down... but injection is cut during deceleration currently, no fuel is dumped.
So that's the story currently... In order of suspects... I believe it is sparkplugs/ignition, injectors (but have been cleaned and reconditioned for this rebuild), or lastly camshaft timing (been checked repeatedly and seems to match everyone elses and is timed properly in the car itself).
So that's it... If I figure it out I'll let you know but I'm certainly interested in any and all suggestions... remember there is NO stock ECU, just the Microtech.. so no cam sensor or the like to worry about... and the Microtech shows all good readings on all sensor banks and reports no errors.
Thanks!
Steve
