Anyone out there with a flashed ECU running a A/F Guage off the stock O2 sensor at the exhaust manifold? I just finished installing my Defi Narrow band and was curious if anybody else with a flashed car had similiar readings.
At idle it sits around 15 and bounces up and down once in awhile but at WOT initially it jumps to 10 for a fraction of a second then settles at 14.5 for the duration of the run. I get the same reading running stock boost or 10lbs. All I have is a Injen CAI and a ION DP. I'm told the non flashed cars run at 10 at WOT with the same gauge.
Thanks,
Thanks,
