njaremka said:if your car is moving, there will always be air flow through the vents.
Todd said:I have a question. When I put the fan setting to 0 I still get some hot air or cold air regardless, I assumed that 0 would mean the thing is off. Is this working as designed or is mine broken???
njaremka said:the only way to by pass it, and still have the fan on, is to take apart your dash and disable the switch that kick the ac in when you turn the knob past the 'floor' setting.
