Introduction
I know there has been on to do it so far, and it was Biknman(sorry for the spelling if its not right) who ran it on his hillclimb/time attack car which used wilwood rotors, caliper, and e-brake w/e custom brackets and spacers. I believe shootz ended up with this setup and later sold it to someone else. However, besides the guys who have swapped to 5-lug there hasn't been many/if any other rear disc setups for the 4-lug cars. So, now to the point of this thread.
Goal
Over the next couple Months I will be planning the install of rear discs on my 00 ES. The information I will cover will be goo for all 99-03 4-lug rear drum proteges. There will be some custom fabrication involved such as mounting points for the caliper brackets. Aside from that and maybe some wheel spacers I don't for see there being too many other troubles.
Parts That Will Be Used
Ford Escort GT/ZX2 Rear Rotors - $17/each - Wagner Brand
Ford Escort GT Rear Calipers w/ Brackets Loaded - $70/Each - Centric
Specification Information
EGT/ZX2 Rotor
Diameter: 251mm
Height: 35mm
Hub: 55mm
Bolt: 4x100
99-00 Brake Drum
Hub: 55mm
Height: 58mm
Bolt: 4x100
Summary
So, As you can see the hub bore and bolt pattern are obviously the same and the height is different, however this is expected since they are entirely different designs for braking. If the wheel sits in any further than this can be adjusted with wheel spacers after the fact, they should not sit out any further though.
Unknown
If I will be able to make the current e-brake cable setup work. If not I will source an escort setup and we will find a way to make it work well.
Brake Line/Hoses I am unsure about as well, but it might be just as easy and swapping to 01-03 5-lug parts.
Expected Costs
$171 - Parts
$100 or less for Fabrication Materials and Friend's Time
So, under $300 Total, and once Done Rear Brakes Services Will be Roughly $15/pads and $25/Rotors.
Once I start moving forward with this I will be posting pictures and a general How-To.
Goal
EGT/ZX2 Rotor
Diameter: 251mm
Height: 35mm
Hub: 55mm
Bolt: 4x100
99-00 Brake Drum
Hub: 55mm
Height: 58mm
Bolt: 4x100
Summary
Unknown
Expected Costs
$171 - Parts
