ok i have a z5 which used to have spark but now it doesn't i was trying to wire a external coil pack and blew some fuses but now there is no spark at all and replaced fuses. the disty and crank sensor resistance tested good.
Here is the part i can figure out also. the coil is inside the disty right so when i try to turn motor over there is no spark but the internal coil is getting hot??????
