97 Mazda 626 question help
jra20
I have a V6 97 Mazda 626 Manuel. Its not going into to gear. There is nothing wrong with the clutch. Im looking for the clutch master cylinder to check the fluid. Well I know where the brake master cylinder is and I know where the clutch one is (its the one thats the same shape as the brake but smaller and in front of it) well there is no resevoir to the clutch one and one line gos to the firewall and the other goes to the engine. How can I put more fluid in it? Or am looking in the wrong spot?
Does the clutch pedal stick to the floor? Have someone help you by pushing the pedal up and down while you look for movement of the slave cylinder on the front of the transmission.. If you have a solid 1" of movement from the slave, than time to look elsewhere, either the clutch assembly itself or in the gearbox.
