91 LX Sunroof Replacement
Skeedaddy
1991 Protege
Who has experience regarding the replacement of a sunroof on a 91 LX? The metal is beginning to rust and I thought about options to replace it. Is there anything good out there that you would recommend? I guessing that it should be professionally done but will wait for all your's advice.
Regards
Skeedaddy
Regards
Skeedaddy
You're talking about replacing the metal panel? If so, you wouldn't believe how easy it is. Open the sunroof about 3 inches, and use a screwdriver to pry the front of the fabric cover (on the bottom side of the panel) down. After you've done that, slide the metal the rest of the way back and ease the fabric cover out.
Slide the sunroof closed, unbolt it from underneath(6 or 8 bolts), push the panel up and it's out...
Put the new panel in place, bolt it down, slide it back and put the fabric cover back in place, and you're done. Next, send me beer.
Bill
