A AWDthis Member : 2007 MazdaSpeed 3 Oct 23, 2008 #1 I was wondering what the difference was because mistakenly i put 5w-20 on my motor and then read the manual(hand)
S strytnyne Member Oct 23, 2008 #2 20 is thinner. i mistakenly did that also last change ended up changing my oil twice. =X
D derekb727 Member : 2003.5 Mazdaspeed Protege #510 Oct 23, 2008 #4 the weight is the same the viscosity or the slickness of it is going to be less.
A AWDthis Member : 2007 MazdaSpeed 3 Oct 23, 2008 #6 Okay What I meant was does it really matter or will this mess up my engine/turbo?
Z ZoomZoomH Member : a Mulligan Oct 23, 2008 #7 for street driving you'll be fine now if you take it to the track, then i'd advise to change to 5w30
A AWDthis Member : 2007 MazdaSpeed 3 Oct 23, 2008 #8 ZoomZoomH said: for street driving you'll be fine now if you take it to the track, then i'd advise to change to 5w30 Click to expand... Thanks! No track for the next 5,000 miles...$40 synthetic oil pwns me...
B bova80 Member : 2007 Mazdaspeed6 GT Oct 23, 2008 #9 ha i wouldnt' go 5000 miles on that, i would change at like 2500 or 3000. with direct injection there is a lot of sheering by the fuel, usually after 5000 miles a 5w30 is more like a 5w20.
T ThreeEdgedSword Member : 07 Mazdaspeed 3 GT Cosmic Blue Oct 25, 2008 #11 10w-60's probably too thick then, yeah?
B bova80 Member : 2007 Mazdaspeed6 GT Oct 25, 2008 #12 wtf would you run that for? i think the most i'd go in this car is a 10w40.
T ThreeEdgedSword Member : 07 Mazdaspeed 3 GT Cosmic Blue Oct 25, 2008 #13 Just joking around - I'm sticking with 5W-30. I've just got a fair amount of both lying around at work.
