My CX-5 is about two months old and I don't spend much time on the road, hence limited MZD Connect usage so far. I'm on version 59.00.504, paired with an iPhone 6 running iOS11.2.5.
Shortly after pairing phone realized several contacts were missing, removed connection and deleted Mazda profile from iPhone, re-paired via BT and still same issue. Then realized MZD Connect max is 1,000 contacts and I've way more than that on my phone. Not a problem at all, as I don't need all 1000 contacts in the CX-5, I'd say probably 25-50 enough for me. Questions:
a) Besides automatically downloading contacts -which yielded prior results- there's an entry to manually add contacts. However, I'm getting stuck there at the "Select a contact to import from the mobile device". For the life of me haven't found a way to select it (eg selected the contact on my phone and no jive, looked on contact options to see if there was an option to share via BT but didn't find one, etc). CX-5 contact list is empty -as I had just deleted the prior connection to start from scratch- hence nothing to select there. I know there are some instructions on the MZD Connect site, but there's no clarity on how to "select SELECTED CONTACT IMPORT" under their Manually import contacts instructions. Has anyone been able to crack this one?
b) Is there a way to manually enter a contact? Or is the only way to import from a paired phone? Can't a contact be created via the touchscreen?
c) Even when I had the 1,000 contacts imported, seems Voice Recognition only able to dial if pronounced as named on contact list. Didn't find a way to dial to contacts in favorites if they were named different (eg "Wife mobile" on Favorites, rather than "Wife" and then selecting "Home, Office, mobile" on next command). Can VR only dial to contact names? Or favorite names as well?
d) On the subject of VR, understand there's a way to train the system to improve recognition accuracy (instructions state press pick up button, say "Voice training" after the beep, and then read out loud the system prompts. However, this must be specific to some models or audio types, as haven't found a way for my CX-5 to even recognize the command "Voice Training". In case it helps, CX-5 is a 2017 Touring with Preferred Package (hence Bose audio)
e) Is there a way to default to a given screen in the Touch screen? I believe it defaults to the last used one, but I would actually would like to make either the "Display off" or "Display off + clock" available on settings to be persistent. Think right now only stays that way until a different screen is selected via any of the commander buttons -eg I'd expect music screen to display for a few seconds after if I selected the music button and then to go back to my choice of screen off, but it's staying in music -or navigation for that matter- until I select "Screen off" again from settings.
Would appreciate pointers for additional documentation on contacts and VR besides Mazda Connect website (eg User guide on PDF, etc)
Thanks!
Thanks!
