3'' Catback Finally
mazdaspeed75
ZOOM ZOOM BOOM BOOM CLUB
2003.5 mazdaspeed
Finally got shop to hook it up custom job 3'' all the way back sounds good. I will try to get some vid whwn i can figure it out . Also finally got my aem wbo2 looks good . Going in a couple of weeks . Sweet
nice, I need to get exhaust done for sure, so if I get a cat-back and then later get a downpipe, is that like replacing the entire exhaust from the turbo back? Or will there still be some stock parts left? Which is the best downpipe to go with? Ion, Hi-boost, Apex???
g
i have the apoex 2.5 catless downpipe to a 3'' resonator to 3'' the rest the way out sounds good and i know its freed up so hp. i hope
when you get the vids, you know who to notify :). btw, what kind of muffler are you using?
h
Ima not sure a local shop did this for me . The only thing is is that the muffle inlet was 2 and 3/4 and 2.5 inside out to 3'' He told me he could get a 3'' all the way throuhj . That is what he was supposed to order, so he is going to try and get another one . Do you think that is hurting my flow , or should i just leave it like it is, It sounds real good. I may get it ceramic coated .
chillinmcmillan said:
sweet so which is the best downpipe to go with?
When people say downpipe they mean different things. Our exhaust goes from turbo S-pipe to a J-pipe, a mid-pipe (with the two cats), and a rear muffler section. Apex replaces the catted section I believe.
mazdaspeed75 said:
Tell Marty thanks got the gauge yesterday waiting for pillar pod and bung to get welded on Thanks alot .
No problem...I will let him know. Let us know if you need anything else.
-Alan
what kind of muffler design is that that the diameter decreases from the inlet?? i mean i guess i could see how the designers would use the reduced diameter to speed up the exhaust flow but it's gonna serve as a bottleneck once you start pushing more flow that it can handle. i'd get it replaced.
They probably just welded a 3" pipe to a 2.5" inlet muffler (meant for 2.5" piping). They probably had it sitting around the shop and thought you would never know the difference.
h
Yea but he was cool about it and said if i get the full 3 '' that he would take that one off and put the new plus he quoted me wrong he told me no more than 200 when i got there he tried telling me 240 i said nope and got it for 200
