I am not sure about the warranty stuff at all because I've never owned a car that had warranty.boost_me said:I dont double clutch, my problem with the grinding occurs from second to third in about 3500-4000 rpms, not all the time tho, very rarley.. My question is if I upgrade my tranny oil to royal purple, for example, shouldnt this "better" lubricant illiminate the problem?
Worked on my rsx typeS when I was boosting it...
Also, If I upgrade my clutch pref. Exedy stage2 if/when it comes out, and I still have a synchron problem, and the dealer sees I have an aftermarket clutch, can that void my warrenty on my trans?
They pulled that BS on my brother and he has an evo.
Dim said:Yup. Double-clutch on downshifts.
You can, but the synchros have to do more work, so technically speaking they will sustain more wear.
On a brand new vehicle you may not notice any symptoms of wear for a long time; however, long-term this may not be good.
I think it's just about the extent to which you are willing to go in order to treat your car well! Like I said, some transmissions are very robust and will do the job reliably regardless of how you treat them. The Protege transmission is crap, so I want to make it last the longest.
Also, watch any circuit race where they show the guy actually driving, you'll see that he's double-clutching on every downshift.
Here you go! These videos are on Google video right now. They were once on Standardshift.com, which is where I learned about them:
http://video.google.com/videosearch?q=standardshift&num=10&so=0&start=0
I think some of them repeat in this Google search, but make sure to watch all of them because this is all you need to know. This guy drives fairly aggressively. You don't have to do that, just learn the idea. Hehe.
Double-clutching (heel-and-toe) at play (Pros Racing stock cars):
http://videos.streetfire.net/video/ba8f93f0-10cd-41ad-ac35-986e015972b1.htm
Okay, so why do you post threads? To tell the world you can't drive a car?clos561 said:not anymore, mazda fixed it...and it was because released the cluitch and gear wasnt in all the way and grinded really bad and broke some teeth
i posted when it was messed up...and i posted when i got it fixed....just keeping everyone informed on my s***...im not going to launch or do any hard shifts untill i upgrade my tranny mount that alot of people have upgraded on this forum...yea i tell the world that this is my first stick shift car and that i made a mistake...and you give a **** y?Dim said:Okay, so why do you post threads? To tell the world you can't drive a car?
