lynnriderm6
Will 245/40/18 fit on a 2010 speed 3? i can get a good deal on winter tires that are these size but i dont want to buy em if its going to rub? thanks
They could rub. The size I run is 225/40/18, which is a bit wider than the 215/45/18 that is on the MS3.
The 2010's come with 225/40/18 stock! 245/40 is gonna be quite a bit wider and taller! If your not lowered.... you might be ok! If you have a Sears auto center or any kind of tire store near you, they can show the diff in height and width to be more accurate for you! I worked in tires for years and used to know this stuff by heart, sorry i can't be more help! Good luck
