"Regarding the stubby wrench you used. Do you think the right size Allen wrench would work just as well?"
I don't think there's enough room for a 3/8" Allen wrench, I could barely get my low profile ratchet in there, the problem is that there is another obstruction opposite of the plug. As you loosen the plug the gap gets tighter, so even if you somehow can get the allen wrench to fit, you won't be able to get the plug out. A right angle 3/8" Allen wrench will be too high, also, without the ratcheting action, it will be very tedious with the Allen wrench, there's absolutely not enough to turn the Allen wrench 360 degrees (maybe at most there's enough space to turn 120 degrees, so you'll have to keep removing and re-inserting the wrench after each turn)
