veritas80
23' CX5 Turbo
- SI, NY
Yes yes, i know this is silly as they are simple plastic pieces but Mazda has in all their infinite wisdom, permanently mounted the clips to the inside of the deflector...You would think there would be a YT Vid showing an OEM install but alas, nothing. My question is the clip seems to be notched to fit into 1 of 2 spots depending on how you slide them into the rubber
. Anyone have any insight with these. The instructions are borderline goofy (Step 6 lol) and there is a small piece of foam they mention but there is only one...again, strange. I tried test fitting, moving them around into different spots without removing the tape obviously and I gotta tell ya, playing around with the fit, scratches the black sash around the windows. Annoying. I attached the directions.
Appreciate any help,
Vin
Vin
