2021 Signature, changing camera view with center knob?
Phoenix
2021 signature
On my 2020 Signature you could change the camera view (front, rear, side, top) by pushing the center control knob. That doesn't seem to work with my 2021 Signature - have to push the camera button on the control panel at the left of the steering column. Can anyone confirm this or is there a setting I'm missing?
I ran into this issue on my old Mazda6 (2018). A software upgrade fixed that issue. Maybe check your software version and compare with the latest.
So to clarify, and the 2021, the command knob should indeed change the camera view of the 360 monitor if you push it? To be clear, I'm curious if this is specific to the 2021, as it did seem to work in my 2020, and specific to the 360 monitor
I forgot you guys got the new infotainment system in the '21's down there.
There is an icon on the screen that I have to select before I hit the commander knob to switch the views. I don't know what is on the newer systems for icons.
Can anyone yet confirm if the 2021 360 monitor changes the view when if you push the command knob?
