Thanks for that option. There must be a way to remove the latch as it is mounted on a small fulcrum-like metal piece. Might have to cut it out with a dremel tool, but hope to find someone with experience removing the latch assembly.
Thanks again!
You have to be careful closing it or there's no question that the latch will break. Best thing to do is squeeze the latch before you lower it and once it's lowered in position release your grip on it otherwise the mechanisms make contact on the way down and eventually the plastic will break.
