Listen carefully at 0:10 second.
Recently my cx5 got some knocking noises from front passenger side when driving in slow speed, combine with uneven road, or bump, or turning.
Notice this is a common issue with Mazda.
Found this TSBS https://static.nhtsa.gov/odi/tsbs/2015/SB-10105646-2532.pdf .
but according this service bulletin, my vin is not in the list.
Also, found this https://mazda.oemdtc.com/122/knocki...-from-front-lower-arm-bushing-2013-2016-mazda
My vin is Type C as descried, and instructs to replace the lower arm bushing only.
However, after viewing my gopro captures, I am suspicious the sound relate to the coil spring and struct bearing, I might need to install protector as descripted in https://static.nhtsa.gov/odi/tsbs/2015/SB-10105646-2532.pdf .
What should I go for? I am so confused here.
