You're in Switzerland and your 2015 CX-5 is equivalent to our facelift 2016 CX-5 which started selling in February 2015. Based on your video you have LED headlights with LED accent strip DRLs. The factory service manual you quoted is for standard halogen headlights in lower trims which use high-beam HB3/9005 (US) or H15 (non-US) halogen bulb with lower wattage.
In any event if the DRLs are required in Switzerland your choice is very limited and expensive. To fix the LED flickering problem you have to get the whole headlight assembly which would cost about $1,200 MSRP each and you're also going to have mis-match issues on light output and color temperature between new J version and original headlight on your right side. A friend of mine is having the same issue with one month over the 3-year warranty and Mazda North American Operations are only willing to help partially. My advice to him is to just let them go without the LED DRLs as they're not mandatory in the US.
Your right side LED DRL WILL fail after your left one. At this stage if in Switzerland the DRLs are mandatory, your best option is to find an aftermarket DRL kit incorporated with your fog lights which will be much cheaper than replacing your factory LED headlights.
Daytime running lights dim/flickering
Thanks for the info. DRL's are mandatory here in Switzerland, but cars without them just turn their headlights on, so no big drama there.
If your 5-year "factory warranty" is bumper-to-bumper, then you're in good hands. You want to pray your right-side LED DRL would fail as soon as possible so that you can have a matching "J" version LED headlights.
I double checked the book today, the previous owner purchased the "4 year and 5 year warranty extension" from Mazda to make the 3 years 5 years. I'll talk to my local Madza garage with the VIN on Monday...
Did you notice that your video is categorized "comedy"?
The nerve! Nothing funny about it.![]()
True true, it's just the default. I've recategorised it more appropriately
