Hi guys/gals,
I have a 2015 Mazda CX-5 without installed rails. Can anyone recommend crossbars that can be directly installed without rails? I'd prefer ones that are bolted down rather than using clamps.
Thanks a lot in advance for your suggestions!
You could remove the black plastic trim pieces in the slots on the roof and find the 6mm mounting threaded holes. Then you could get a much better idea of what you need.
