Hi all, my partner and I would be most grateful for your advice.
Mazda Cx5 2.2 Diesel 2015 model with around 65k miles on it. Due to the regulations where we live, we can not sell the car within 2 years of purchase and are therefore ‘stuck’ with it.
Background:
Repair 1: Change of the coolant bypass (plastic) to metal.
- We picked up the car around two months ago (import). Unfortunately within the first 10 minutes of driving we had a red engine overheating sign. We discovered that the coolant bypass was leaking. As such, it was carried back to the capital city where the coolant by-pass was changed.
- We also undertook DPF delete at the same time.
Repair 2: Change of the gasket and cylinder head.
- A few weeks later, we noticed loss of power while acceleration and overheating once again.
- Failed the block test (colour changed to green quickly) and intense pressure in the coolant system.
- On opening up to fix, not only was the gasket gone but also the head cylinder was unfortunately cracked too.
Repair 3: Change the radiator.
- No issues or challenges with the drive but noticed a small leak in the bottom side of the radiator while regular monitoring. As such, this was changed.
Repair 4: Change the EGR and re-do the gasket.
- We noticed white smoke coming through the exhaust system.
- As a result, the mechanic reviewed.
- Tested the EGR via engineers and it was found to be faulty too, and so was changed.
- They also redid the gasket.
Current Issue/Dilemma
- Having picked up the car, there is still white smoke (see attached video).
- It failed the block test (it took a while this time, but the colour did eventually change to green and the pressure in the system appeared to be high).
- We have a temperature reader for the engine/coolant system and it is not overheating (around 85-95 in regular use).
- Mechanics are offering to do the work without labour price included, at parts price
- Options:
Background:
- Options:
- Change the engine block (by process of elimination, as the gasket, head and the XX have been changed – all were also damaged). Does this seem reasonable or could there be other components that should be considered prior to spending on the block change? The rationale would be that the issue is coolant system related – as failed block test, so evidence of combustion gas in the system. Most likely also explains the white gas in the exhaust too.
- Change the entire engine to a second hand one (more expensive) – same rationale as above, but also acknowledges that there may be other engine related issues.
- Could there be two separate issues – issue with the coolant system (per block test, as above) and the smoke in the exhaust due to another issue? For example, related to the DPF delete, injectors, leaky seal or overfuel in the map etc.
