2014 CX-5 Floor shakes at high speed
Hello folks new to this forum, has anyone with the Gen 1 Cx-5 ever had the shaking floor (more noticeable on the passenger side) at high speed? I have ruled out the tire/rim/balance possibilities. I replaced the driver-side CV-axle earlier as it was more noticeable on the driver side and it fixed it. Now it seems the passenger side started acting up just like the driver-side two years ago.
Does this seem like a worn inner CV joint-related symptom?
Hello folks new to this forum, has anyone with the Gen 1 Cx-5 ever had the shaking floor (more noticeable on the passenger side) at high speed? I have ruled out the tire/rim/balance possibilities. I replaced the driver-side CV-axle earlier as it was more noticeable on the driver side and it fixed it. Not it seems the passenger side started acting up just like the driver-side two years ago.
Since it fixed the driver side maybe it would fix the other side, too., but who knows?
Do you notice binding or knocking noise when you make sharper turns at low speed?
No there was no knocking sound as a typical failed CV joint does before I replaced the driver side axle, not this time either-I think it does not make a knocking noise if it is the inner joint.
