Hey everyone. I've got a 14 CX-5 that needed wheel bearings replaced. I accidentally damaged the sensor trying to get the heavily rusted hub & bearing out. Fearing I'd damaged the knuckle, I also replaced that with a used one. The problem is the bolt in the take off part that holds the sensor snapped off in the steering knuckle. I have a new sensor ordered. What's the best way to remove that snapped bolt from the knuckle so I can replace it?
