2013 Mazda 3 Headlights Blink when Brakes applied
tomfooter
2013 Mazda 3
Has anyone experienced this problem I am having with my 2013 Mazda 3? If your Headlights are on and you apply the Brake, the lights will start blinking like there is a voltage drop. The don't go off, but dim just a bit and brighten, dim and brighten about twice every second while the brake pedal is down. I have even noticed my interior light will do it too, if it happens to be on. I have no idea what the brake light or park lights are doing at this time, because I haven't had anyone follow me yet. The headlights have never gone out, just start blinking. I just bought this car (used) about a month ago and it seems like it has done it since I have owned it. Anyone ever hear of this and what may be causing it?(help)
According to Consumer Reports, there's a TSB on this... here's the listing they have:
Service bulletins
2010-13 models might need an updated rear stabilizer due to a squeak, knock, or rattle (8/13).
2012-13 models with Halogen lights need a software update if they flicker when applying the brakes (19/13), and may also need an updated #4 engine mount for a squeak when starting from a stop and/or shifting (13/13).
Sounds like there is a known issue, I'd call the dealership tell them the issue and that you understand there's a software update for it.
My dealer was aware of the TSB and reprogrammed the PCM. About $45 out the door, and most importantly, works.
- Rick
