2010 Toruing Front brake pads and hardware clips questions
2010 CX-9
Are the front brake pads on this model oriented in inner and outer pads? Or are both pads the same and it doesn't matter which side of the rotor they are on?
the hardware clips that come with. The side away from the rotor has tabs that stick out past the rotor bracket. are they meant to be bent over against the bracket to help hold the clip in place or is this not required?
I used auto zone pads and they were the same inside and out. They go either way. The clips should snap in but there is no need to bend them over or do anything to them. Some pads sets come with wear indicators that usually attach to the top of the inside pad but it is separate from the clips. Hope that helps.
