PizZeL said:I dont understand why you cant boost in 5th gear? Is the engine that weak from the factory? Are the internals forged or just cast? What compression are you motors stock?
SilversunMSP said:How realistic is this? I've been considering the FMIC and I've got the Mazdaspeed exhaust already. What else do I need to see close to 200 whp reliably?
PlatinumMSP said:dude you'll need a better exhaust than the Mazdaspeed one, basically i'm kind of going off the unichip formula, http://corksport.com/content/00/01/06/61/73/uploaded.files/chart.jpg
basically i think they hit 200whp with just an intake and catback exhaust at 10psi
chwood said:didn't he say he doesn't want to increase boost though?
and then, 2ndarily, wouldn't someone see better results replacing turbo-axle than cat-back?
(fingers crossed since I am doing just that on Saturday LOL)
SilversunMSP said:From what I've seen, a high flow exhaust/cat setup and the FMIC will usually cause an increase in boost by 1-2 psi. Do I really need to upgrade the fuel system (ie; injectors, pump) with just these two mods? Will I need some kind of fuel/ignition computer with these mods in order to still run safely?
PlatinumMSP said:Well i'm finally almost there everyone.... and now i'm trying to get input on my final mod to put me over the top.... EMS & EBC ... vote your opinion here: http://www.msprotege.com/forum/showthread.php?t=123640500&page=3
keep in mind that I will be getting tuned no matter what and my mods at the time of install will be:
GHL Turboback Exhaust
Injen Cai
HiBoost FMIC w/ Greddy Type S
AWR Motor Mounts
Blitz Dual Turbo Timer / Boost Gauge
thanks
Matrix said:Hey, just to make sure...you have changed your spark plugs to a colder plug, right? (poke)
