OK, I’ve done my testing on the relay and here’s the what I have found pin number 30 on the AC relay is supposed to be the B+ so it stays hot all the time 87 is the load side. It should only be hot whenever the relay engages, therefore sending power on through to the AC compressor, well here’s the problem I have no power whatsoever no 12 V on pin number 30 regardless it never has no power, but I have power on the load side pin 87 all the time so to me it’s just backwards and whatever is causing this. I have no idea I don’t know where to look at anymore, but I feel like if I could get it figured out to where 30 has to be and 87 doesn’t have nothing until the AC is turned on my problem solved so on 30 and the fuses are good, I sure would appreciate it. Thank you.
