2007 BMW 335i Dynamometer Run
mikeyb
Contributor
01 BMW 325xi Touring
The 2007 BMW 335i will be in showrooms next month, and is the first application of BMWs new twin-turbocharged 3.0-liter inline-six. This is a big deal because BMW has had only two short affairs with turbocharged gasoline production cars--the 2002 Turbo in the mid-70s, and the E23 745i in the early 80s--and neither was sold in the U.S. As the saying goes, third times the charm.
BMW fit this new engine with two small-displacement turbochargers--instead of one larger unit--in an effort to reduce lag. And for the most part, it worked. Behind the wheel, youre vaguely aware that this engine doesnt have quite as crisp a throttle response as its normally-aspirated siblings do. But you dont care--youre too busy trying to hold on for dear life.
This is one hell of a motor, pulling smoothly and strongly from idle all the way to its 7000-rpm fuel cutoff. Theres no boost gauge, and since you barely hear the turbos spooling, its easy to forget theyre even there. Once youve adjusted to the slight lag in power delivery following big, sudden throttle openings, all you notice is the sound of that silky in-line six.
BMW says that this engine makes 300 horsepower and 300 lb-ft of torque. We were so impressed with its power that we couldnt help wonder if that was a conservative rating. Wasting no time, I swiped the keys and drove to a local dyno shop to find out.
We used a DynoJet chassis dyno, which measures an engines power output at a vehicles rear wheels. Because of frictional driveline losses, this number is always lower--generally by fifteen to twenty percent--than the quoted power output from the manufacturer, which is measured at the engine itself.
Heres what we found:
The non-turbocharged 330i, rated by BMW at 255 hp and 220 lb-ft of torque, puts about 200 hp and 180 lb-ft to the rear wheels. Thats roughly a twenty-percent loss. Since they have similar drivelines, youd expect the 335i to put down 235 hp and 250 lb-ft.
But it didnt. It put down a whole lot more: 275 hp and 300 lb-ft. A few quick taps on our trusty calculator shows that this engine is likely putting out closer to 350 hp and 360 lb-ft of torque.
Technical editor Don Shermans ears perked up at all this number crunching. With all that power, he wondered, is the 335i faster than the outgoing 333-hp E46 M3? We waved goodbye to the shiny new coupes rear tires, and sent him to find out.
Don coaxed the 335i to 60 mph in 5.1 seconds--only 0.3 seconds slower than the M3. The 335i covered the quarter-mile in 13.6 seconds @ 104 mph--again, only 0.2 seconds and 1 mph behind the M3.
So in an all-out drag race, the 335i comes close, but cant quite match the M3s blistering acceleration. Those numbers, though, only tell half the story. Have a look at the top-gear acceleration figures. In sixth gear, the M3 needs 14.7 seconds to get from 30 to 70 mph but the 335i does it in only 12.5.
That, my friends, is the beauty of this engine. At full bore, its as fast as an M3. But at moderate engine speeds, its even faster. What a great way to keep us all interested until the next M3 comes along.
Test - M3 - 335i
0-60 - 4.8 - 5.1
0-100 - 11.5 - 12.7
0-110 - 14.5 - 15.6
0-120 - N/A - 18.6
0-140 - N/A - 28.2
1/4 mile - 13.4@105 - 13.6@104
peak g - 0.7 - 0.68
30-70 (6th) - 14.7 - 12.5
30-70 (3rd) - N/A - 6.5
70-0 - 162 - 150
Peak g - 1.12 - 1.12
Weight - 3480 - 3560
%F/R - 50.6/49.4 - 51.1/48.9
Redline - 8000 - 7000
Power - 333 - 300
Torque - 202 - 300
Tires 255/40 ZR-18 255/35 WR-18
<TABLE cellSpacing=0 cellPadding=0 border=0><TBODY><TR><TD>
</TD></TR></TBODY></TABLE>
source:http://www.automobilemag.com/features/news/0609_2007_bmw_335i_dynamometer/
RacerXGirl said:
I think I need one of these in my life...
And what would you do with a 335i? I'm waiting for my BMW dealer to get one in so I can go test drive it.
Attention all MS6 owners, be on high alert for another stealth rocket. Do not engage unless victory is assured.
I must also add that this is the best looking Bangle-ized bimmer yet. Quirky but it does not make my eyes bleed.
I'd love it and hug it and drive it and wash it and wax it and drive it some more... :D
Being the 3 series, I was thinking the same thing, but versus the MS3. We'll have to see what the real world figures for the MS3 are.
R
R
Why would you even compare the 335i to the MS3? Completely different market segments. If the 130i M-sport or 135i M-sport makes it here compare them to MS3.
BMW even has a Sedan and Sportwagon (Touring).
[FONT=Arial, sans-serif]Arriving in US showrooms this September, the newest BMW Coupe once again sets the standard for design, luxury, and performance in its class. The 2007 3 Series Coupe will have a starting MSRP of $35,995 including destination and handling.
As is typical for BMW, significant enhancements to the standard features as well as the value of the new 328i and 335i have been made, compared to their predecessors. In addition, BMW's xDrive all-wheel drive will be available for the first time in a Coupe in the 328xi. While base prices have increased versus the outgoing versions, the new 3 Series Coupe models now include a substantial number of additional features including:
[/FONT]
  • [FONT=Arial, sans-serif]More powerful engines (230 and 300 hp vs. 184 and 225)[/FONT]
  • [FONT=Arial, sans-serif]More differentiated styling from the sedan[/FONT]
  • [FONT=Arial, sans-serif]Xenon adaptive headlights with cornering lights standard[/FONT]
  • [FONT=Arial, sans-serif]Rear side head protection system (airbag curtain)[/FONT]
  • [FONT=Arial, sans-serif]Enhanced DSC benefits (including brake drying, brake stand-by, brake fade compensation, and start-off assistant)[/FONT]
  • [FONT=Arial, sans-serif]Enhanced interior ambiance lighting[/FONT]
  • [FONT=Arial, sans-serif]Run-flat tires with Tire Pressure Monitor[/FONT]
The 328i also receives the following additional standard equipment:
[/FONT]
  • [FONT=Arial, sans-serif]17" wheels and tires[/FONT]
  • [FONT=Arial, sans-serif]6-speed manual transmission[/FONT]
[FONT=Arial, sans-serif]In fact, compared to the top-of-the-line 2006 330Ci Coupe, the entry-level 2007 328i Coupe not only offers greater style inside and out, as well as a number of safety enhancements, it also offers even better performance - all for $2,500 less.
The list of options for all models now includes a six-speed STEPTRONIC automatic transmission. Option packages for both models represent even greater value with added content as well.
Ownership value has been enhanced with the announcement of BMW Ultimate ServiceTM , a suite of services that includes the BMW Maintenance Program (formerly called Full Maintenance) , Roadside Assistance, the New Vehicle Limited Warranty and BMW AssistTM with Teleservice. The new 3 Series Coupes will have BMW AssistTM available as a stand-alone option or as part of the optional Premium Package. As before, included with BMW AssistTM is Bluetooth hands-free phone connectively which includes hands-free access to your phonebook. Starting with model year 2007, BMW AssistTM will be provided for four years. Most other similar services cover only the first year of service.
The 2007 BMW 328i Coupe will be priced at $35,995 while the 335i Coupe, with its 300 horsepower twin-turbo inline six cylinder engine, will have an MSRP of $41,295. The new 328xi Coupe, with BMW's advanced xDrive all-wheel drive system, will retail for $37,795. All prices include a $695 destination and handling charge.
[/FONT]
FlipandFunk said:
i know rite, ms3 is the new SRT4. hotted up cheap econobox. No bmw 335 owner would cross shop a turbo mazda3. lol
I consider the MS3 a stepup from the Caliber SRT-4. Because it will have better build qualty.
FlipandFunk said:
it might be, but its no bmw. Besides Mazda3 is still behind the civic in build quality so its not saying much.
Atleast its in front of the Caliber and Sentra.
