2004 MPV dies on low rpm
maz-vic
Batterie does not get charged in idle or low rpm while driving
I'm thinking loose belt but the tensioner sits on the mark in the middle
When i press on the belt in front of the tensioner I can easily push it down to the tensioner
On higher rpm voltage at the batterie measures not more than 12.7V
Anybody any suggestions?
Thanks in advance
just replaced the belt -alternator is charging -get 14.7V at the batterie, but it is whining pretty loud and got hot in a few minutes
I could turn the pulley by hand when the belt was off, but it had a bit resistance
let the alternator cool down started the car again -whining is gone, but now it is not charging under 2000 rpm
