2004 Mazda 2 Sport ODB II Error Codes
didmug
2004 Mazda Demio Sport
Hello All,
I have a 2004 Mazda 2/Demio with about 45000 miles on it.
Using the Maxiscan MS309 ODB II/EODB reader for diagnostics, I get the following 8 error messages:
1/8: P0715 $07E8 Generic
Input/Turbine Speed Sensor A circuit.
2/8: P0351 $07E8 Generic
Ignition coil A primary/secondary circuit.
3/8: P0733 $07E8 Generic
Gear 3 Incorrect Ratio.
4/8: P0841 $07E8 Generic
Transmission fluid pressure sensor switch A circuit Range/Performance.
5/8: P0031 $07E8 Generic
HO2S Heat Control Circuit Low Bank 1 Sensor 1.
6/8: P0351 $07E8pd Generic
7/8: P0841 $07E8pd Generic
8/8: P0031 $07E8pd Generic
So can anyone tell me what needs to be done, in terms of dealing with these errors? Much appreciated.
Regards,
Dan.
I'm not a pro mechanic, and my 2 is a newer generation. Is it possible that the ECU is Damaged? That's a lot of issues that seem not hugely related.
