2004 Lingenfelter Pontiac GTO
mikeyb
Contributor
01 BMW 325xi Touring
Tuners: 2004 Lingenfelter Pontiac GTO
With the emphasis on "Oh!"
Motor Trend, August 2004
<!--begin paragraph-->Many petrol heads consider the 1964 Pontiac GTO to be the first real musclecar. Pontiac is hoping its latest GTO will be as successful as that original of four decades ago. The 2004 version offers plenty of adrenaline-pumping hardware (350-horsepower Corvette-sourced V-8, six-speed gearbox, tight suspension, and sporty 17-inch wheels), and its performance is solid--but there's room for more.
Answering the call for added thrust and improved grip is Lingenfelter Performance Engineering. One of the aftermarket's best LS1/LS6 engine tuners, LPE has released a series of GTO packages that give the Goat more gallop. Although three engine packages are available, we tested LPE's base package with "only" 450 horsepower, representing a 100-horse step up from stock.
The increased power comes by way of CNC-ported cylinder heads carrying stainless-steel valves, dual valve springs, titanium retainers, and H-D rocker-arm stands. A custom roller camshaft teams with an LPE cold-air inlet, port-matched manifold, and ported throttle-body to mix air and fuel.
<!--end paragraph-->
<!--begin paragraph-->Exhaust chores are handled by LPE stainless-steel headers ($1095) and a free-breathing Corsa stainless-steel exhaust system. LPE's custom software allows the engine to run on pump fuel, and the combo is pending 50-state smog certification. The engine package costs about $6900 (depending on options) and comes with a 2-year/24,000-mile warranty.
<!--begin paragraph-->On the street, the powertrain proved perfectly docile. At the track, it was downright brutish. Despite wheelhop at launch (a problem inherent in the GTO's IRS), the LPE GTO chopped a full second off 0-to-60 and quarter-mile sprints. Stopping distance was dramatically decreased as well, thanks to Baer Racing's new GTO brake system that incorporates 14-inch cross-drilled rotors clamped by PBR two-piston calipers ($1449).
The stock GTO is already a handler, but the factory's tire choice (all-season tread) proves to be a limiting factor. LPE ups the game with a set of AMG-looking Mille Miglia 18x8.0-inch alloys wrapped in sticky BFG g-Force T/A KD 245/40ZR18 tires. LPE's custom adjustable ride height suspension with coil-over front struts, Koni adjustable shocks, adjustable rear spring perches, front strut tower brace, subframe connectors, front castor bar bushings, polyurethane IRS bushings, and custom alignment specs (package is $1760) team to improve the GTO's handling persona. More aggressive 3.91:1 rear gears work with a H-D diff cover ($1720). In our slalom tests, the suspension and rolling stock proved effective as the added grip and increased predictability delivered a solid 2.3-mph increase in average speed. On the street, the suspension proved smooth on good roads, if a bit choppy on L.A.'s mottled freeways.
We like how the LPE package provides plenty of punch while remaining fairly undercover. And as is typical of this tuner, its stuff just works. If you want even more rumble from your Pontiac, consider LPE's 427-cube GTO package (535 horsepower, $21,000 installed) and/or its supercharger package (130 additional horses, $9500 installed). Any way you go, you're sure to surprise a few Corvettes and SVT Mustangs.
<!--begin paragraph--><TABLE class=insettxt borderColor=#000000 cellSpacing=0 cellPadding=2 width=460 border=1><TBODY><TR vAlign=top><TD class=insettxt></TD><TD>2004 GTO</TD><TD>2004 LPE GTO</TD></TR><TR vAlign=top><TD class=insettxt>0-60 mph</TD><TD>5.3</TD><TD>4.3</TD></TR><TR vAlign=top><TD class=insettxt>1/4 mile</TD><TD>13.6 @ 104.7</TD><TD>12.6 @ 113.5</TD></TR><TR vAlign=top><TD class=insettxt>Braking, 60-0, ft</TD><TD>120</TD><TD>113</TD></TR><TR vAlign=top><TD class=insettxt>Slalom, mph</TD><TD>63.5</TD><TD>65.8</TD></TR><TR vAlign=top><TD class=insettxt>Skidpad, g </TD><TD>0.80</TD><TD>0.88</TD></TR></TBODY></TABLE>
<!--end paragraph--><!--end paragraph--><!--end paragraph-->
That's kinda outdated already. New GTO's are using the LS2 which puts out 400HP.
I drove a 1999 Lingenfelter Corvette a while ago. ******* amazing. I've actually been looking at the new GTO for a while. But I drool over cars all the time. More than likely, I'll be buying a house this year despite my primal instincts to trade in my car for something truly fast.
