I recently changed the coils, intake gaskets, pcv valve, fuel injector o-rings and valve cover gasket on my 2003 Tribute with 160,000 miles. It ran great for a couple of hours then while on the freeway it lost all power and I had to floor it to maintain enough speed just to exit. It starts fine and seems to shift fine but when I drive it the vehicle will only get up to about 30mph and wants to stay under 2200 rpm. The more gas I give it the worse it performs.
I sprayed MAF cleaner around the vacuum lines and gaskets I replaced and no fuel is leaking. It appears to be holding vacuum and the fuel pressure at the test point maintains 65psi. When I idle it up to 2000 rpm (in park) I can feel the motor pulsing a bit. Some have suggested it is a catalytic converter. The EGR valve is also really really hot.
Why am I not getting a trouble code? If it is a catalytic converter, how do I tell which one. They are expensive as heck and I can't throw that much at random part replacement.
Edit; As a last resort I was out putting some seafoam in the vacuum lines. When I turned the car off I could hear a 2 second pssssht sound coming from the back of the motor. Is this normal, could it be the vacuum canister making the noise?
Also no rotten egg smell.
