I've kept decent care of my Protege over years. I've kept up with the scheduled maintenance and replaced the oil regularly. Now my car seems to be burning oil. "I say" it's burning oil because I don't see it leaking anywhere and the oil light comes on at least once a month (sometimes more). There were some days when I would start the car in the morning, white smoke would come out of the muffler for about 5-10 seconds, then it would stop (it was not cold on these days). Now, I don't see smoke anymore, but it's still burning oil. Who knows maybe the sensor is bad? The car has never overheated, and even when the oil light comes on, the temp seems fine. I usually put a quart of high mileage oil in the car when the light comes on.
I drive 120miles a day for work (round trip) and want to see if I can keep this car for at least 1 more year (if not 2). I enjoy not having a car payment, and I'm not of the opinion that I should just ditch this car to buy a new one just because it's old. So, some of the local mechanics said it could be a few things: head gasket, o-rings, valve gasket. From what I can tell, valve gasket leak seems to be the most likely (i've never used fuel treatments).
So, having said all of this, what do you guys/gals think the problem might be? Is it time to replace the engine? or is the problem on the surface enough to fix without removing the engine? Anyone in the Houston area up for a job?
