2003.5 spoiler
PHSMsp04
I have a 2003 MSP and was wondering if they sell the 2003.5 spoilers somewhere. if anybody knows a site that sells them please tell. thanks
I believe they are like $350 from the dealer. You should see if anyone with an 03.5 will just trade with you. I know I have heard several people who said they liked the old style better.
thanks. do u know if the newer spoiler lines up with the holes the other one fit into because i know the newer style doesnt have the middle section.
Other than the holes, I believe they are identical. You would have to fill or plug your holes & the person who gets your wing would have to make new ones for the center post. Then there is the repainting :( ...
All you have to paint is the wing unless you want the holes filled & painted. You COULD just plug them with color-matched plugs, but if you want it to look perfect, then yes, you would need the whole trunk lid painted.
someone suggested putting in a sirius antenna there.
i happen to have an 03.5 msp spoiler make me an offer
Having the antenna under the spoiler would cause reception problems...satellite radio is very sensitive to it's reception. And unlike regular radio, which just gets static-y if you lose a bit of reception...satellite radio is either on or off...either you get crystal clear reception or no reception at all.
No, the spoiler will have no effect on the reception of the Sirius signal. It's made of plastic or fiberglass, and does not interfere with the reception. Only metal impedes the signal. Sorry, Jersey. However, I think that would be a bad mounting spot for the antennae. I have mine mounted directly behind the back glass, on the trunk lid. Remember, that wire will visible if you mount it too far away from the trunk.
