Forgot if this has already been mentioned, but you absolutely should buy new urethane front and rear motor mounts or buy the urethane inserts if you don't want as much vibration from the engine being transmitted to the car. If you go the insert route, be sure to check the condition of your existing mounts as they may already be shot. The motor mounts are a big problem on this car and can lead to cracking of the exhaust manifold, J pipe, or the exhaust itself. All of which are big headaches.
I have the inserts, and they made a huge difference in the amount of vibration transmitted to the car and I personally wouldn't recommend going with the all urethane insert for a car you plan to keep mostly stock and DD. The car will shake.
