2002 Protege5 Htchbk - No Heat and Vent dial not working!! help?! it's winter!!!!
Jeebus057
Mazda Protege5 hatchback
Hello everyone!!! Thanks for your help ahead of time!! I can't afford 800+ $ to open the dash and console to determine what's wrong and replace the right parts. OR hopefully it's just a clip or wire i can adjust... but only with your help!!
#1 I just bought a 02 protege5 hatchback and because it's warm in AZ, I didn't realize there is NO HEAT coming out of the vents when i use the temp dial. The AC works, but the temp dial doesn't adjust the cold air either.
#2 The vent selector dial doesn't change anything either. I have no air blowing on the windshield, but there is air from all other vents.
WTF do I do?? What do I check??
Thank you again for any help and info!!
Brian
What OP is describing is cables not clipped in correctly if at all. He isn't saying my fan only blows on 1 and 4. That is different issue. Post #2 above should cover OP's problem.
Not sure what the weather report above has to do with anything, lol............
