2002 Mazda Protege 5 Won't Fire
Engine won't fire. New fuel pump, pressure fine, checked ignition switch, good. Has oil. Everything works engine just turns over and over ?
Check fuses. Chec MAF connection. Pull a plug and look at it. Use a timing light to see if you are getting spark.
+1: fuses, plugs, coils
no check engine lights?
You need spark, fuel, and oxygen so one of those isn't getting delivered to your cylinders. Sounds like you're getting fuel just fine so try the other two. When you say "pressure fine" do you mean fuel pressure or compression in the cylinders?
