2001 Protege Throttle Positition Sensor location question
bowiefan
mazda protege
I was wondering where the throttle position sensor location was on a 2001 Protege with a 1.6L engine. Any help would be appreciated. Thanks.
Should be on the right side of the Throttle Body TB, opposite the coil up mount for gas pedal cable. It should be mounted with 2 bolts.
I'm thinking 2.0L, you sure its 1.6L you have there?
