2.3L Turbo JDM Engine Swap. Need Help
2007, Mazda CX 9, AWD Sports
I need help. I swapped my 08 cx-7 engine with a JDM Engine imported from Japan, now the car cranks but it won’t start. All fuses and relays are good and I hear the fuel pump is also pumping. Any thoughts?
I would appreciate any advice...
If you pull a plug do you see fuel mist or smell fuel when cranking? Have you verified you are getting spark? Do you get sputters or just nothing at all?
