haha yea. Cell phone was all I have on hand currently. The flash just made everything look off so I just kept it off. I'll get up with 323 soon and get some proper shots.
ok so because of my thermal spacers i had a little too much tension on my throttle cable causing higher idle and the car not dropping rev's when i step off the gas. Quick adjustment on my 505 throttle cable bracket and that problem is fixed. Also somehow one of my cluster bulbs got burned out so i went ahead and replaced all of them.
also right now i feel like i have a huge boost leak some where because i'm not having my power hit till top end. So ill go through and have that pressure tested soon. Ill also hook up a boost gauge to see exactly how much boost im currently running.
just Ordered:
Mpi Tuner w/ Extra injectors
Dg Grill
AEM Failsafe gauge
Joe P FCD
FM o2 Modifier
GM 3bar Map Sensor
work rs black lug nuts
greddy profec type b boost controller
