2.0L Skyactiv AC Bypass?
So i own a 2012 mazda3 with the 2.0L skyactiv motor. The ac pulley seized and i dont wanna go through the hastle of buying a used one and the install of there is anybody here that knows a belt bypass. I called all my local shops and none of them knew because it is on the alternator and waterpump pulley and all these motors came with ac. If anybody knows a belt size to just void the front-mount ac it would be appreciated. i cannot find anything online about it
Take a string. Preferably a string that won't stretch.
Loop it around where the belt you want should go.
Measure string.
Get a few belts around that size. Return what won't fit.
Make sure the AC pulley isn't in the way of the new belt or you may have to remove the compressor.
