1st Gen CX9 - Fuel Filler Neck
2011 CX-9 GT AWD
Hello everybody,
I think I am having an issue with fuel filler neck on 2011 cx9 gt.
I found some wet spot on left hand side of the tank( gas filler side). The drive way is slope and it happened only with full of tank. does anybody have any instruction how to replace fuel filler neck?
Received your report notification...I'd like to try and help find an answer if possible, hopefully others can chime in as well (@Bronco Boy any ideas? :)). Have you come across this thread...It came up when doing a search for the issue you're experiencing...
Or this one... Gas cap / Fuel Filler Cap Issue
I checked this Mazda parts site and perhaps the diagrams could help..?
This video also came up that might shed some light on the repair although it's not a Mazda...
I've gone as far as removing the fuel door release, but didn't pay attention to the filler. Should be clamped at both ends, so will have to gain access from inside to do or see anything for the upper part.
Best to get under the vehicle to see where it is leaking from; could be the filler, could be the sender, could be a hole in the tank, or could be any of the multiple hose connections on top of the tank.
