1st and 2nd gear problem!
m4rty08
2007 masdaspeed3
i got a problem when shifting gears after i replaced the turbo hoses top and bottom and screwed all the bolts hoses. when i drove it from 1st gear and press the gas it chokes multiple times even in 2nd and 3rd gear. i pretty much double/triple check all the hoses,bpv,everything. and i even unplug the battery 2 times, but the problem is the same. i also checked the plugs,coils springs, and all the hoses. But no luck! i just replaced couple of stuff like BPV,Shifter bushings,sure shortcut,
btw i was trying to unplug the plug for the TB and broke the red thing that releases the plug. i was wondering do need to reprogram the Throttle Body if i unplugged it? HELP ME PLEASE!
solved it! it turns out to be a cut wire from ecu harnesses, the clamp from my turbo inlet had cut the wire and caused me those problems.
