1993 Civic guru's i need your help
Sean2010
2010 Mazda 3
OK, I have a couple problems here. Hook me up with some advise.
Car wont rev past 3500rpm. Its like it just bounces off the rev limiter. Odd right? Map sensor perhaps or in limp mode?
Next, there is a fuse in the fuse box called "Back-up". I was trying to read the codes via the plug but the light wouldn't blink. I seen that "back-up" fuse was blown. So i replaced it. However, here is where it gets tangly. When i installed the new fuse, the dash lights come on (oil, bat, cel) and stay on, even when i key isnt in the ignition. When i started the car like this, it will not turn off even when i take the key out. If i remove the good fuse from the "back-up" it will start and turn off fine.
WTF is up with my car?! lol
BTW, motor has 600K on it
